Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Creating a bowed panel for 3d printing
10 REPLIES 10
Message 1 of 11
dheiser4
445 Views, 10 Replies
I am trying to create a replacement part for my car. It has to be a bowed piece with some holes to mount items. Is it better to create flat with holes in it then bend or create bent and add holes? I am fairly new to CAD. I have created a panel which fits but can't figure out how to make the holes or if it is better to lay it out flat then extrude and bend.
I am using the most current version of Fusion 360. Most of the tutorials I've found are for older versions which don't have all the same controls.
10 REPLIES 10
Message 2 of 11
edcharlwood
in reply to: dheiser4
I think, as you want to 3D print it, it'll be a case of try it and see. The part from the image looks so thin I cannot think there will be a discernable difference as the wall thickness is negligible so the tapering/vcurvature of the hole through would hardly be noticable. However, having a flat part to take the measurements from will certainly be easier IMHO.
Message 3 of 11
dheiser4
Thank you for your reply.
The panel is 2mm thick. What I need to know is how to bend or bow a flat panel after I have the holes in it.
Either that or how to push the hole through the bent panel. I can't seem to figure out how to lay a circle on the angled face.
Message 4 of 11
edcharlwood
If you've already got a curved surface you could offset a plane, sketch the circle and extrude cut it.
Or if it’s a cuboid you can sketch the circle and extrude cut it out, then sketch arcs on the end of the cuboid and extrude remove them to leave a curved shape.
Message 5 of 11
dheiser4
I really appreciate the help but I guess I'm over my head on this. What I really need is someone in Rapid City SD to teach me CAD.  I don't do well with online learning. I haven't been able to find a class here.
Message 6 of 11
edcharlwood
Draw the part you need with as much detail as you can I’ll do it for you with a screen record?
Message 7 of 11
dheiser4
Very rough sketch. The hole will be flat on front and back to mount a USB port. Panel is 2mm thick as I scribbled that.
Message 8 of 11
dheiser4
Here is a link to what I have so far
https://a360.co/41yNSc8
Message 9 of 11
edcharlwood
Here you go, I hope both approches work for what you need. I didn't do dimsnsions, just for speed.
Let me know if you need any more help.
Ed
p.s think about the overhangs when you 3D print  - you might need to do it end-on and add a brim for stability.
https://a360.co/3IeWz4F
https://a360.co/3M8HSB5
Message 10 of 11
dheiser4
Thanks. I will play this back in slow motion a few times to get it all. Appreciate the help Ed. I think I can figure it out from here. I'll share with my friend I've been working with on this.
Doug
Message 11 of 11
dheiser4
Just about have it.  Thanks Ed.
https://a360.co/3BJmKg3
You've got Fusion.
