Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Create tool holder - cant find ER32 in standard library
2 REPLIES 2
SuncoastTechnicalCollege
116 Views, 2 Replies
We are using Introduction to Cad, Cam and Practical CNC machining. In CNC milling basics it says to create a digital tool.
Can find holder in standard library. I am testing this out so I see same products as students
CNC Machinist Education Network
https://www.youtube.com/c/CNCMachinistEducationNetwork
2 REPLIES 2
Hi Ed. I believe this was a library at the time the content was made, but some changes to tool libraries since then has changed what is now available.
Let me check with some of the parties involved tomorrow and find out.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Hey Ed, it seems that the blanks were moved to that folder in the library under "Holders - Standard Taper".  Not sure when that happened but you did find the right blank referenced in the pdf/video.
At around 4:45 you modify the height to 1in, and the holder geometry does change.  I think for some reason when you hit enter it is Accepting the tool edit.  For me when i hit enter it jumps to the next available value (upper diameter) in row 9.  Not sure why that is.  But what you showed in your video is the correct  behavior.  We are just showing the copy and edit of a standard CAT40 holder making the height match what an ER32 would be.
You've got Fusion.
