Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Core extracting not done
3 REPLIES 3
nitin_sarvade
159 Views, 3 Replies
i don't understand how to extract core from mould in fusion 360
3 REPLIES 3
kellings
in reply to: nitin_sarvade
Hi @nitin_sarvade Do you have a file you can attach that shows the problem? There are a couple of possibilities here but it will be easier to show you if I have the data you are working with.
Generally this is done using the combine tool and sometimes the boundary fill tool.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
nitin_sarvade
in reply to: kellings
any tutorial is available ...please send
dan.banach
Hi @nitin_sarvade
The Fusion 360 YouTube channel has videos that will help you mater Fusion 360.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
You've got Fusion.
