Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Converting one body into different components
1 REPLY 1
eorhon
101 Views, 1 Reply
Hi, I created a bridge model on Fusion 360 however. It is all one body and I'm trying to simulate my bridge. Thus I need to convert my bridge and its strings into different components. However, how do I divide my one body into different components and connect them as components so that I can simulate it?
1 REPLY 1
dan.banach
in reply to: eorhon
Hi @eorhon
Here are instructions on how to split a body.
Then to convert a body into a component do the following.
  1. In the browser expand Bodies entry
  2. Right click on a body and click Create Components from Bodies.
Note that the features will not carry over to the component. If possible, we recommend creating a new component first and then model that part. Then continue creating new components as required.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
