Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Connecting two different shaped bodies
4 REPLIES 4
Aviaman
212 Views, 4 Replies
Hello, im trying to connect a square tube, and a round tube that have a smooth transition...is there a tool to help me do this by selecting the faces to connect and it builds the bodies together?
4 REPLIES 4
Aviaman
in reply to: Aviaman
Ok, I have found "loft" but i seem to be having trouble; I select the two faces and then im having issue creating rails or really anything else
kellings
I’m guessing the two shapes you are trying to connect are hollow. You need to create the loft of the two shapes while they are solid. Then either shell or create another loft to hollow out your part.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
edcharlwood
Can you add a screenshot of the work?
Aviaman
in reply to: kellings
Thank you, this was the issue; kind of weird why I cant do it for two hollow tubes but okay...thank you for the solution
You've got Fusion.
