Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
CB-RTO ??
4 REPLIES 4
SuncoastTechnicalCollege
166 Views, 4 Replies
CB-RTO ??
CNC Machinist Education Network
https://www.youtube.com/c/CNCMachinistEducationNetwork
4 REPLIES 4
Hey @SuncoastTechnicalCollege I'm not sure what this means. Are you able to access the files you want, or can you still access your files?
I'm checking with the Data team to see if they can give me some info on what this message pertains to.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
I found this. I usually ignore those messages because I've never seen a problem when those are up.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Req...
Hi @SuncoastTechnicalCollege
Thanks for posting about the CB_RTO message. Here is what I learned. This message appears while the data is syncing, then it should go away. Let us know if the message persists.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
thanks everyone. I think our school internet may be lagging. I was hardwired on both teacher machines and now trying wireless to see if it improves
You've got Fusion.
