Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Can’t log in to use fusion360
3 REPLIES 3
t_zong
118 Views, 3 Replies
Every time it restarted to the start page after I entered my account and password. I tried reinstall it and restart my computer but it doesn’t work.
Tags (1)
3 REPLIES 3
dan.banach
in reply to: t_zong
Hi @t_zong
Can you give us more information.
  1. Are you running a Windows or Mac?
  2. Did this issue just  start / where you able to log into Fusion previously?
  3. Can you attached an image of the error that you're seeing.
Please try the following.
  • Close Fusion
  •  If you're on a Windows computer, delete all files from locations below, and then run Fusion.
    • C:\Users\(your user name)\AppData\Local\Autodesk\Autodesk Fusion 360
    • C:\Users\(your user name)\AppData\Roaming\Autodesk\Autodesk Fusion 360
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
in reply to: t_zong
Hi @t_zong
The Engineering team looked at your account, and you were not an active member of a Fusion Team. After you're invited into a Fusion Team, you'll receive an email and from the email you need to accept the invitation to join this Team. The Engineering team was able to do this for you. You should now be able to log into  need to Fusion Team mail106223.
Keep us posted.
-Dan
Dan Banach
dan.banach
in reply to: t_zong
Hi @t_zong
Can you please verify that you can now log into Fusion?
-Dan
Dan Banach
You've got Fusion.
