Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
can someone help
10 REPLIES 10
Message 1 of 11
Milsteinarlo
265 Views, 10 Replies
can someone help
How do I make this part less slanted? I am very new, so if you can help, please explain detailed Thanks!Screen Shot 2023-07-18 at 12.44.07 PM.pngScreen Shot 2023-07-18 at 12.44.30 PM.pngScreen Shot 2023-07-18 at 12.44.17 PM.png
10 REPLIES 10
Message 2 of 11
kellings
in reply to: Milsteinarlo
Hi @Milsteinarlo Can you share the file? You can go to the file menu and choose export and then choose Fusion 360 archive format, or you can right click on your file in the data panel and choose "share link".
If you need more help with that, let me know.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 11
Milsteinarlo
in reply to: kellings
Message 4 of 11
Milsteinarlo
Message 5 of 11
kellings
Thank @Milsteinarlo I was able to open your file. Can you explain further what you want to change about it?
Kevin
Kevin Ellingson
Message 6 of 11
Milsteinarlo
the outside part that is like a semi circle I want to make the edge connected to that wanted instead of just an abrupt height change
Message 7 of 11
kellings
@Milsteinarlo Something like this?
Kevin Ellingson
Message 8 of 11
Milsteinarlo
haha not exacty what i was thinking i am trying to make a piece to fit around this part and was just trying to make the inside corner smoother where the two shafts would go
Message 9 of 11
kellings
Is your goal to have the blue part fit as a negative in the grey part? Do you have a file for the blue part?
Kevin Ellingson
Message 10 of 11
Milsteinarlo
thank you so much for your help but I figured it out!
Message 11 of 11
dan.banach
Hi @Milsteinarlo
Can you tell us what you did to solve the problem?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
You've got Fusion.
