Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Can Educational License use the new Plastic Function?
3 REPLIES 3
eduabbot
408 Views, 3 Replies
Hi all,
Such as Snap fit or boss, those function are very important for my product design students.
3 REPLIES 3
dan.banach
in reply to: eduabbot
Hi  eduabbot,
Thanks for the question. Valid Autodesk Education Accounts can access many of the Fusion 360 Extensions including the Product Design Extension. To add an Extension, follow these steps.
  1. While in Fusion 360, on the top-right corner of the screen click on Extensions.
  2. In the Extensions Manager Dialog box, select the desired Extension.
  3. Then in the dialog box click Start Access. The following image shows the Nesting and Fabrication Extension.
  4. The Extension will now be available. Note that most of the extensions are available for 30 days. At the end of 30 days you'll need to repeat steps 1 - 3. This is the same experience that our commercial clients have. They can use extensions for the time period that they need.
Please let me know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
eduabbot
in reply to: dan.banach
Very nice!
Thank you!
MattPerez314
In addition to that make sure you go to the User Preferences and into the Preview.  Volumetric Lattice and the Design Assistant tools are both in PDextension but are preview and need to be activated I do believe.
You've got Fusion.
