Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
appearance of extruded part
2 REPLIES 2
r.chandraQ38SV
103 Views, 2 Replies
Hello All,
I am relatively new to Fusion 360.
I seem to have changed some type of setting unintentionally.
Whenever I extrude parts the appearance of the parts are unshaded and appear hollow.
Is there a way to change the settings so that all extruded parts have shaded/solid appearance?
I have tried the material and appearance commands with no results.
See below a screen shot of what I mean by unshaded/hollow:
Raj
2 REPLIES 2
dan.banach
in reply to: r.chandraQ38SV
Hi @r.chandraQ38SV
Please try changing the Display Settings.
  1. On the bottom of the screen, in the Navigation bar & display settings bar, click on Display Settings > Visual Style > Shaded with Visible Edges Only.
    Or
  2. Use the shortcut key Ctrl+6 (Shaded with Visible Edges Only).
Does this answer your question?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Thank you Dan...that worked.
You've got Fusion.
