Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Animatronic Joint Problem
2 REPLIES 2
sacbe.aguilar
144 Views, 2 Replies
Hello!
I'm having quite a hard time adding a joint that would allow the servo's horn to rotate and push the rod to close the eyelids.
Does anyone know what I am missing?
Labels (2)
2 REPLIES 2
dan.banach
in reply to: sacbe.aguilar
Hi @sacbe.aguilar
Thanks for posting your question. A couple ideas.
  1. Have you tried using Joint Limits? Joint Limits  prevent a joints from moving beyond its expected range. Link to article that explains Joint limits.
  2. If you have multiple joints whose movement are dependent on each other, i.e. gears, you can use a Motion Link. Here is a link to a tutorial that covers Joint Limits and Motion Link.
Do other have suggestions?
Let us know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
sacbe.aguilar
in reply to: dan.banach
Hey @dan.banach
Thanks so much for the links. They definitely helped my process. I changed the revolute joint that moved the eyebrow to a ball joint. I have to work on the limits and motion links. For now, I can finally move on with this project.
Thanks again 🙂
You've got Fusion.
