Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
after update no drawing function
7 REPLIES 7
Message 1 of 8
lab
218 Views, 7 Replies
After the last update, I'm not abble to make any drawings. Also the the programm screen freezes.
Any idea ?
7 REPLIES 7
Message 2 of 8
Marco.Takx
in reply to: lab
Hi @lab,
Sorry to hear that.
Maybe your update didn't roll out well.
Can you try to re-install Fusion 360 to see if it solved the problem.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Consultant
Message 3 of 8
lab
in reply to: lab
Done. Same Problem.
Message 4 of 8
kellings
in reply to: lab
Hi @lab @I’ve seen this happen with a handful of users. Can you update your graphics driver from the manufacturer that makes your graphics card?
Let me know if that sorts it out.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 5 of 8
lab
in reply to: lab
Also done, does not work.
Message 6 of 8
kellings
in reply to: lab
How many monitors are you using?
Kevin Ellingson
Message 7 of 8
lab
in reply to: lab
Problem solved. Had to download the driver from nvidia and it works!!! Thanks.
The driver out of microsoft automatic search does'nt work, though it says "you driver is the actually best"blabla...
Message 8 of 8
kellings
in reply to: lab
Glad you got it @lab . The Windows drivers are usually out of date compared to what you can get from the driver builder. That was the part of the reason in my reply I noted to go to the manufacturer of your card to get your driver there. The Windows drivers are pretty good for things like bringing up a computer after a clean install, or USB, bluetooth, utility things like that. I always go to the card vendors website to get the drivers they offer.
Kevin Ellingson
You've got Fusion.
