Fusion Educators
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
3Dconnection SpaceExplorer no longer works in my Fusion360!!!
5 REPLIES 5
czecht
247 Views, 5 Replies
After I've updated to the newest Fusion360, my SpaceExplorer no longer works!!!
Why would they fix one bug and introduce more bugs?
Can anyone tell me if there is a fix for this problem?
Thanks!
5 REPLIES 5
dan.banach
in reply to: czecht
Hi czecht,
Sorry to hear that your SpaceExplorer is not working. Could you try the steps listed in this 3D Connexion knowledge article and let me know if this solves your issue?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
MattPerez314
in reply to: czecht
I had a few people tell me their 3dExplorer devices stopped working and the thing that worked for them was changing the SpaceMouse driver setting in User Preferences back to "Legacy".  I would give that a shot and see if it works.  I think the "latest" driver often times is the culprit.
czecht
in reply to: dan.banach
It works now, so thank you for your help!
It would be nice to have default set to LEGACY and a popup can inform people to change it to newest driver....
There is lot more users like me that have older, but functional hardware that Logitech stopped supporting - what a shame.
czecht
in reply to: MattPerez314
Thank you!
It is now working like it did before.
I think that when Fusion does update, they should leave this in LEGACY mode and not change it to "newest driver"!
MattPerez314
in reply to: czecht
@czecht glad it worked!  I believe that if you set the driver as legacy your user preference will stay until you restore defaults or manually change it.  The only thing that will affect the user preferences would be a complete uninstall/reinstall or the change of a preview feature being released that must override your setting.  An old example of this was the UI change years ago.  It was in preview but eventually phased out the old UI.
You've got Fusion.
