Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Unable to render Cloud with education license Issue?
16 REPLIES 16
Message 1 of 17
ENGİNŞANLI
708 Views, 16 Replies
I have a training license. When I come to the render setting page and select Cloud renderer, the render tab at the bottom is grayed out, it does not allow me to click. Normally, it should write 16 credits, but it does not. When I click on the local render, the render tab becomes active. Is there a new regulation about this? I would be glad if you help..
16 REPLIES 16
Message 2 of 17
lucasliraAU
in reply to: ENGİNŞANLI
Hello @ENGİNŞANLI
In a few weeks I have also been reporting about this problem that the rendering interface is facing, I thought that this conflict was happening only with my installation, I observe that other users are facing similar problems.
This week some updates were implemented, I'm going to do some renderings to see if the problem persists, report back here!
Link to my publication can be found here.
https://forums.autodesk.com/t5/fusion-360-educators/starting-cloud-rendering/m-p/11588308#M1956
@dan.banach  is also aware of this occurrence.
See you soon.
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
Message 3 of 17
lucasliraAU
Hi, @ENGİNŞANLI
I went to look at the dashboard and am also facing the same issues unfortunately.
Message 4 of 17
dan.banach
Hi @lucasliraAU
Thanks for also reporting this issue. I'll ask the team if there are any issues with the backend system.
@ENGİNŞANLI & @lucasliraAU I'll keep you posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 5 of 17
lucasliraAU
Hello, @dan.banach  thank you for your attention on this occurrence!
I've been investigating this since a week ago, some updates have been released, however the problem is still persistent.
My resolution so far for this occurrence:
The problem is persistent for some users of the platform, I have already found 3 publications with the same occurrence.
The tests I've done so far:
- The Fusion 360 update is the latest available from Autodesk.
- Already open multiple files to re-evaluate the possibility of a new rendering run, however the problem is also persistent for other files.
- Sign in as my educational account on a secondary workstation I have in my prototyping lab - I also have the same issue.
- All credit settings are valid for an educational account (this has already been correctly monitored).
All the attempts listed here in this summary that I made available can help the Fusion 360 support team find a way to solve these interferences with some users on the platform, I believe it would be interesting to make a summary and keep it pinned so that new reports are not duplicated here and also the information can be concentrated to find the solution for this occurrence.
Thank you for your feedback, I hope to cooperate with this operation.
Greetings from Brazil, Lucas Lira.
Message 6 of 17
dan.banach
Hi @lucasliraAU & @ENGİNŞANLI
Can you confirm that you can render locally? We're looking into why the Individual licenses are persistent for your two accounts.
-Dan
Dan Banach
Message 7 of 17
dan.banach
To help the team figure out what is going on, can you please post your Fusion 360 Diagnostic file? Here is an article that explains How to collect the Diagnostic Log Files for Fusion 360
-Dan
Dan Banach
Message 8 of 17
lucasliraAU
in reply to: dan.banach
@dan.banach  Locally the execute render button is active to proceed with the process!
Message 9 of 17
lucasliraAU
Hello, @dan.banach
Fusion 360 has already processed the .ZIP files (Diagnostic Log Files). I already have the file here on my machine where can I publish it right here?
Message 10 of 17
dan.banach
Hi @lucasliraAU
Yes, please post the diagnostic zip file here.
Thanks for your help.
-Dan
Dan Banach
Message 11 of 17
lucasliraAU
Hello, @dan.banach
Attached for reference!
Thank you, I await news.
Message 12 of 17
dan.banach
Can you please try to render to the cloud with Standard quality option instead of Final and see if this works?
-Dan
Dan Banach
Message 13 of 17
ENGİNŞANLI
when i checked this morning i saw that this problem has been fixed by autodesk. cloud credits. system is back to normal..thanks to everyone who helped.
Message 14 of 17
dan.banach
Hi @ENGİNŞANLI Thanks for the update, glad the issue is fixed. The team made a change last night to how the system is looking at cloud credits.
@lucasliraAU
Can you also confirm that you can now submit cloud renderings.
-Dan
Dan Banach
Message 15 of 17
lucasliraAU
Hello, @dan.banach
I've been watching and yes, now it's possible to run the rendering, can you tell me what could be happening, maybe a server congestion? or a priority queue for running the process.
Message 16 of 17
dan.banach
Hi @lucasliraAU
The team changed how Education accounts were looking at cloud credits. Thanks for raising this issue so we could fix it.
-Dan
Dan Banach
Message 17 of 17
lucasliraAU
Thanks! @dan.banach
Greetings from São Paulo.
You've got Fusion.
