Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Trying to create a to path to make drumsticks on a 4-axis
19 REPLIES 19
Message 1 of 20
thedoncutta
594 Views, 19 Replies
Hello Community,
     Im a High School percussion instructor and I'm trying to help my students make drumsticks. Im new to fusion and i have to idea how to complete this, i do have the stl. and my machine is calibrated. I just cannot figure out the tool path function in fusion. Your help will be greatly appreciated
19 REPLIES 19
Message 2 of 20
kellings
in reply to: thedoncutta
Hi @thedoncutta can you provide the file you are trying to use here? You can right click the file in the Fusion data panel and choose share link. You can then paste that link here and I'll take a look. Can you also tell me what tool or tools you want to use to do this?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 20
kellings
Hi @thedoncutta Were you able to make any progress with this? Do you still need help?
Kevin
Kevin Ellingson
Message 4 of 20
thedoncutta
in reply to: kellings
No we haven’t made progress would you like me to upload some stk. and maybe you can do a vid I can show the class? Thanks for responding
Message 5 of 20
kellings
That would be great. A link to your file would be helpful. Also, let me know what tools you want to use like flat end mill, bull nose, ball nose etc. and the diameters as well as the stock size you want to start with.
Kevin Ellingson
Message 6 of 20
I am a Snare drummer from drum and bugle corps - Boston Crusaders.  Thats my drum stick I just took a pic of on my teacher desk.
Drumstick with 4th axis. I would use rotary tool path.  - maybe use 3d adaptive from A zero and A 180. for roughing.
Workholding - the problem is the same as cutting wooden balsa CO2 dragsters - Fusion Academy used to have a course on it. I saved it.   The problem is holding it.   I would mount on end with a 5c collet or lathe chuck and o support with a tailstock.  machine everywhere except the ends you hold it by.  - hand sand ends
CO2 dragster machining Video
CNC Machinist Education Network
https://www.youtube.com/c/CNCMachinistEducationNetwork
Message 7 of 20
Im in the middle - Plymouth Mass parade every November before Thanksgiving
Message 8 of 20
thedoncutta
Please find the link attached.
thanks
https://a360.co/3NTiHTs
Message 9 of 20
Nice....I play with The Casper Troopers we did the parade in November!!!! Im the short guy on snare in the middle left.
https://a360.co/3NTiHTsIMG_0668.JPG
Message 10 of 20
thedoncutta
Heres the link
Message 11 of 20
thedoncutta
File
Message 12 of 20
kellings
Hi @thedoncutta Here is first example of this. Have a look and see if I'm doing what you were hoping for. I implemented @SuncoastTechnicalCollege's suggestion and rouged the stock from A0 and then from A180. I applied two rotary toolpaths. One using the spiral option, and one using the linear option. Have a look at the file and let me know what changes you would like and I'll get it dialed in and see if I can make you a start to finish video showing the process.
https://a360.co/3fV7XHS
Kevin
Kevin Ellingson
Message 13 of 20
kellings
@thedoncutta I should also note that you will have to enable the manufacture extension to edit the rotary toolpath. If you need any help with that, please let me know.
Kevin
Kevin Ellingson
Message 14 of 20
thedoncutta
Thanks family a video will be great to show the kids…I’m bringing my cnc to the school to make sticks for a project.
Message 15 of 20
thedoncutta
this is awesome...my stock is .75 x20 "....how do I animate the tool path and create a gcode?
Message 16 of 20
kellings
@thedoncutta If you click on setup1 then on the actions panel you can click the Simulate with Machine icon.
Then when in the simulation, press the play button at the bottom of the screen
Kevin Ellingson
Message 17 of 20
kellings
Hi @thedoncutta Here is a video showing a method for roughing and finishing this part. If you need help making changes or don't follow something, just let me know.
(link to the video file from my OneDrive account)
https://bit.ly/3E155Rw
Kevin
Kevin Ellingson
Message 18 of 20
Nice - Love the Troopers.   The way the west was won
Message 19 of 20
thedoncutta
I have been trying to create a g code allday but to no avail. I keep getting errors, your help will be greatly appreciated. Thanks
Message 20 of 20
kellings
Can you tell me what post processor you are using to try to export your NC code please?
Kevin
Kevin Ellingson
You've got Fusion.
