Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Trouble stitch
2 REPLIES 2
anthonyglorioso
185 Views, 2 Replies
Trouble stitch
I'm having trouble with stitching the dragons neck in this model (body 13)  so it is a solid piece and not hollow.  Fusion says there is an error but doesn't explain why.  Any help will do.  Link is below. Thanks!
https://a360.co/3tDskvW
2 REPLIES 2
Hi Anthony,
I like your model. I found a slight gap in the horns. I figured this out by:
  1. Combined the surfaces individually until I saw the issue.
  2. Removed the 3 bodies that formed the horns. Kept one body that represents half of a horn.
  3. Deleted a face on the inside of the horn, turning the body into a surface.
  4. Mirrored the surface.
  5. Stitched the surfaces and closed the gap
  6. Created a Patch surface
  7. Stitched the 3 surfaces together, forming a solid.
  8. Mirrored the horn to the other side.
See the attached .f3d file. Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Thank you so much.  Appreciate your time helping
You've got Fusion.
