Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Title Block in Drawing templates.
1 REPLY 1
athomasP56VK
185 Views, 1 Reply
Above is the title block as it displays.
then when the student highlights the title block it is visible.
When the student exports the drawing as a PDF or then prints the drawing, it is all visible.
Another student, when not editing the title block, everything is visible, then when they edit it, all of the lines of the title block then disappear, this has been a on going temperamental issue throughout the year.
Any help greatly appreciated.
1 REPLY 1
kellings
in reply to: athomasP56VK
Hi @athomasP56VK @I would start with the graphics driver on the problematic computers.  Go tje vendor for your graphics card add update the drive from their website. Please don’t use Windows update for this as often it won’t find new drivers or the drivers it does have are out of date.
Can you do some investigating starting there please and report back what you find?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
