Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Subscription Expired - Read Only
3 REPLIES 3
samaharjan
166 Views, 3 Replies
[To better track the issue, Admin moved message to its own post]
Still saying expired subscription - read only. even after windows fully reset.
3 REPLIES 3
dan.banach
in reply to: samaharjan
Hi @samaharjan
Looks like your default Fusion Team / Hub is set to gmail358XXXX (owned by John M.) was set to Inactive. I changed the status to Active. Please try to sign into Fusion now.
You are also the Admin for Fusion Team tamu3140, you could make that your default Fusion Team.
Let me know if this solves your issue.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @samaharjan
For security, I change your default Fusion Team to tamu314. If you need access to John’s Fusion Team please ask him to change your status to active.
Please keep us posted.
-Dan
Dan Banach
dan.banach
Hi @samaharjan
Wanted to check in and see if you are now able to sign into Fusion and access your Fusion Team.
-Dan
Dan Banach
You've got Fusion.
