Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Student not allowed to share project folder
3 REPLIES 3
jcolletteG5ZSK
210 Views, 3 Replies
I have a student who attempts to share his project folder with me, the teacher, but it says he does not have permission to do so.  Any ideas?
3 REPLIES 3
dan.banach
in reply to: jcolletteG5ZSK
Hi @jcolletteG5ZSK
Sorry that you're having this issue. A few questions:
  1. Is the student trying to add you to the Project as a Member or just Share a Link?
  2. Is the student on their own Fusion Team and Project?
  3. In Fusion, on the top-left corner of the screen, does it state (Education License)?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
jcolletteG5ZSK
in reply to: dan.banach
1. He is trying to add me as a member.
2. The student created the Team and the project.
3. We are using the online Fusion.  I am not finding where it says Educational License.  Sorry, this is my first time using Fusion.  I did go into Help => About and found that it says that the Active Plan is Student.
dan.banach
Hi @jcolletteG5ZSK
Thanks for the additional information. Please ask your student to follow the steps below to add you to his / her Fusion Team / Project. For detailed instructions refer to pages 23 -27 in the attachment in this post: Autodesk Resource: Using Fusion Team and Folder-Level Project in the Classroom
  1. Log into Fusion Team https://login.autodesk360.com with your Autodesk ID
  2. Ensure the top-level project is active. When a Role is assigned at the Project level, you'll be able to see what is in all sub-folders. The image shows project DES 101 active.
  3. If you haven't been invited, click on the Invite button.
  4. Select a Role. Reader can view files in Fusion but CAN'T save. Editor can create and Save files.
    1. If you were already invited, the student can select your name in the list and assign you a Role.
  5. You'll receive an email inviting you to the Fusion Team / Project. Open the email and click Join Team.
  6. Then in Fusion, show the Data Panel, use the Team Switcher (1) to make the desired Fusion Team (2) active.
Please let us know if this helps.
-Dan
Dan Banach
You've got Fusion.
