Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Some students have share public links option grayed out.
2 REPLIES 2
mguengerich
182 Views, 2 Replies
On the ones who it grayed out, they DO have "Yes" chosen in "Allow file sharing for all" in the Admin settings (both for their own work in their own team or if they are in a shared project in my team).
2 REPLIES 2
dan.banach
in reply to: mguengerich
Hi Mark,
Thanks for the post. Are you using the new Folder-Level Projects? If so, this is a current limitation, but the team is working on this.
If needed, you can create a legacy project from Fusion Team:
  1. Log into Fusion Team by going to https://login.autodesk360.com
  2. To show a list of projects on the Fusion Team, click the Fusion Team icon "F" in the upper-left corner of the browser.
  3. On the right side of the screen click on "Create Project".
  4. Type a name for the project and then click, shown as step (1) in the following image.
  5. Select the Project’s Security Type from the pull-down list, shown as step (2) in the following image.
  1. Open: Any team member can access this project.
  2. Closed: Only invited members can access this project.
  3. Secret: Only invited members can see this project.
  4. Folder-Level: A secret project with granular permissions for each folder (default)
Note: Once a Folder-Level project is created, this project’s security type cannot be changed.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
mguengerich
in reply to: dan.banach
Yes we are using folder level.
Thanks for the info.
You've got Fusion.
