Hi @danielS977W I had to do a couple of things to get the result you were after.
Step one was to use the move command.
Set the move object type to Sketch Objects
select your sketch entities that you want to move. I turned off the other two sketches to make this easier.
Choose the rotation option
I then selected the X axis. You could also choose the bottom horizontal edge of the sketch to rotate about
I then rotated your sketch 1 degree.
The steps above get your sketch parallel to the other sketches.
I had to do one more move to get that sketch on the same plane. I again used the move command
Make sure you are still set to move type sketch objects
Select that sketch again
Use the translate option
I had to move the sketch -0.25997 mm to get it on the same plane.
If you have any trouble getting things sorted out, let me know and I'll see if I can come up with a better step by step.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
