Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Simulations has correct start point but machine does not start there.
2 REPLIES 2
genefeldmanaz
175 Views, 2 Replies
I just got my Onefinity  X-50 Woodworker and I am using Fusion 360. Brand new to all this. I generated a simple square block of wood with a depressed hole in the center. When I run the simulation it works great. Start point is in the middle. When I run the program on my machine it starts machining at the homed corner of the work piece.
I homed the machine first then use the probe block to set the front left corner of the workpiece before running the program.
I’ve spent hours on videos and the web and have tried different changes. Always the same result.
Any help is greatly appreciated.
2 REPLIES 2
I just realized I probably posted to the wrong board. Sorry about that. I’ll repost on the Fusion 360 support page.
dan.banach
in reply to: genefeldmanaz
Hi @genefeldmanaz
If you're an Educator, this is the correct forum. If not, the Manufacture forum would be the best place to post this question. Let us know.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
