Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
rotation of a component
1 REPLY 1
mahdi.yousef.my
103 Views, 1 Reply
In the attached photo, I want to rotate the link shown. The rotation is as follows: I want to keep the right circle(rod) centered at the shown point and rotate the whole link around an axis passing by this point counter-clockwise so that the left circle is also centered on the shown point which is on the same line as the first one. The result is that if I draw a line between the two centers , this line will be parallel to the one shown and passing by these two points. please any help
1 REPLY 1
Hi @mahdi.yousef.my
Can you tell us what you've tried so far? I'd suggest that you will need a series of Joints and Tangent relationships.
Getting a chain to cycle through a multiple components may not be possible because of the different conditions that will be required.
Does anyone have a suggestion?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
