Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
"Expired subscription - Read Only" message appears despite a valid license in Fusion 360
7 REPLIES 7
Message 1 of 8
noel.fabro
765 Views, 7 Replies
Hello there
I downloaded the Fusion 360 Admin install.exe
After install, I opened it and get this error message:
Expired: Subscribe now
I clicked the Expired Subscribe now button and was taken to this website
https://www.autodesk.com/education/edu-software/overview?sorting=featured&filters=individual
In there it shows:
Hi Noel,
Your educational access to Autodesk products is valid through February 7, 2024.
So i'm confused why fusion 360 says it's expired.
But when I go to my Autodesk Account, I don't see under All Products and Services, Fusion 360
can you please advise?
thanks
Noel
7 REPLIES 7
Message 2 of 8
dan.banach
in reply to: noel.fabro
Hi @noel.fabro
Thanks for posting your question. Confirming your eligibility gives you access to Autodesk Education software, but you need to acquire a license for the individual software.
To acquire a Fusion 360 Education license, do the following.
  1. Log into the Autodesk Education site and if needed verify your eligibility.
  2. To acquire or renew your Fusion 360 license; on the Fusion 360 product card click "Get product".
  1. Then click "ACCESS"
  1. Launch Fusion 360.
  2. If the Education license does not appear on the top of the screen as shown in the following image, sign out and back into Fusion 360.
Please keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 8
noel.fabro
in reply to: dan.banach
hi @dan.banach
thank you very much for your reply.
here's what i get when i go to the autodesk education site
As you can see, it shows my educational access to Autodesk products is valid through February 7, 2024.
but under Fusion 360, i only have Get License. When I clicked it, i get this prompt
I tried signing out and signing back in but still get this button Get License
kindly please advice
thank you
Message 4 of 8
dan.banach
Hi @noel.fabro
Thanks for the screen capture. It looks like your Education profile is set to IT Admin. It Admins can only get software for their school lab computers (no individual licenses). What is your role at your school?
-Dan
Dan Banach
Message 5 of 8
noel.fabro
Hi @dan.banach
I am the IT Computer support for Cabramatta High School.
How do I get the license please?
If I install it in our computer labs, would students have the same issue?
thank you
Message 6 of 8
dan.banach
Hi @noel.fabro
If you need to run Fusion 360, can you ask a teacher to assign you a license. See page 8 in the article Educator’s guide to onboarding and offboarding students.
When you install Fusion on the Lab computers, I'd suggest following the steps in this article: Fusion 360 lab install process.
Note: The Individual install of Fusion, will install Fusion under the active profile. Hence why I recommend installing Fusion using the Lab install instructions.
Students and Educators can acquire an Education License of Fusion. The steps are documented in the same linked article.
Does this help?
-Dan
Dan Banach
Message 7 of 8
noel.fabro
thank you Dan
I thought as the IT Support, I would get the license and give it to the teacher?
That way I can also test it?? The process here seemed to be disconnected??
I will let the teacher know and ask him to get his eligibility confirmed as a teacher and assign license to me and the students
Message 8 of 8
dan.banach
Hi @noel.fabro
Good question. The licenses that Educators can assign is limited to 125, and is intended help educator quickly get their students running with Fusion (bypassing the Eligibility process). IT Admins still control the installation of the traditional licensed software that requires network licenses.
Hope this helps.
-Dan
Dan Banach
You've got Fusion.
