Problem with exporting stl file
93122311550
93122311550
Hello!
I'have finished my work on the joystick handle and want to prepare it for 3D printing. The main part of my design was created from mesh->solid converted part, and I'have modified it to mach my expectations, but at the finish of the job I have a problem with exporting it. The case is, when I make mesh export and select the proper body, fusion says there is an error and no data was writen. When I try the export -> stl , after the long time exported part consist of only tiny little cylinder without my parts. I've tried to open it online, but there is an error "no geometry sth...".  When i make all my sketches and bodies invisible in fusion, there is this tiny little cylinder left... I have no idea how to deal with this problem.
All parts I've made are solid bodies, with no errors, I can edit the etc, but not export to stl nor 3mf etc, maybe someone faced this problem?
Best regards
Pawel
kellings
Hi @93122311550 Can you attach your Fusion file here to investigate?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Ahh i found a solution, there was a "base future" active, after I've finished it, i can export all type of files as always, thank you anyway!
