Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Printing Drawing from Fusion Online
1 REPLY 1
scott.wilsonPZ2CH
202 Views, 1 Reply
How do you add a printer to Fusion Online? I have a printer attached to my device however, I am only able to print using Microsoft Print to PDF or Microsoft XPS Document Writer. When I use the Fusion 360 app on my pc it automatically gives me the option to select my printer. Just to double-check, I accessed Fusion Online on my PC and was given the same 2 print options as my other device.
1 REPLY 1
Hi @scott.wilsonPZ2CH
Thanks for the post. The online version of Fusion 360 has no access to local data like printers, but you can print the file from Fusion Team. Can you please try the following:
  1. Go to Fusion Team https://login.autodesk360.com and sign in using your Autodesk ID (email you log into Fusion 360).
  2. Within Fusion Team, select the desired project and open the drawing file.
  3. On the bottom of the screen click on the Print icon.
  4. Select a printer.
Please let me know if these steps allow you to print your drawings.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
