Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Patterns
4 REPLIES 4
rstQSMSM
194 Views, 4 Replies
Patterns
Hi
I am running Fusion 360 2.0.16488 x86_64 I am trying to do a rectangular pattern by selecting features to pattern.  It seems to only allow me to add one Feature or one ace not multiples.  Is this correct?
Cheers
Rob
4 REPLIES 4
kellings
in reply to: rstQSMSM
Hi @rstQSMSM You can select multiple features in a pattern. In the pattern dialog where it says "Objects" you can click that and then any features that you want to add. The first time, you shouldn't need to hold down any modifiers like CTRL or CMD. If you edit the pattern, you may have to use CTRL or CMD to add more selections.
If you can't get it to work, please attach your file and a description of what you want to pattern and I will see if I can provide you a solution.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
rstQSMSM
in reply to: kellings
Hi Kevin
Thank you for the reply. See link below
https://a360.co/3NjKE7g
Fusion<>
Share 2D and 3D design files and project files with anyone.
a360.co
As you can see the last few operations on the timeline are pattern features. I am having to do multiple pattern features as it seem that I cannot select all faces or features at once.
Regards
Rob
kellings
Hi @rstQSMSM Attached is your file with how I did this. I deleted the last few patterns you had. I then patterned one of the patterns and the original features in a symmetric direction and I believe I got the result you were looking for.
One thing I did have to change to make this work is the compute type. Note that I have this set to optimized to get the final results.
Let me know if you have any questions as to what I did.
Kevin
Kevin Ellingson
kellings
Hi @rstQSMSM Were you able to get your issue resolved? Can you let me know where you are at with this one?
Kevin
Kevin Ellingson
You've got Fusion.
