Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Oakland Technical High School Engineering Academy to visit Autodesk
3 REPLIES 3
terrance_holliday
152 Views, 3 Replies
My name is Terrance Holliday, the Career Liaison at Oakland Technical High School. Approximately 25 of our Engineering Academy Scholars are specifically interested in visiting the Autodesk Facility or any company in Northern California that utilizes the Autodesk Platforms. It has been challenging to get in touch with someone at the Autodesk Headquarters in San Francisco for this request.
 We are also open to guest speakers to present about projects and career paths.
Please let me know if you have any connections or suggestions.
Thank you in advance.
Peace
Terrance Holliday
[For security, Admin removed personal information.]
3 REPLIES 3
Hi @terrance_holliday
I'll check and see if the The Autodesk Gallery is open for public tours.
Click n this link to request a Fusion workshop from an Autodesk Learning partner.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
I looked into your request for a tour of Autodesk. Unfortunately, the Autodesk Gallery is not currently open for public tours. This is something that may change in the future.
Hope that a learning partner can assist you with a guest lecture. Link to request a Fusion workshop from an Autodesk Learning partner.
-Dan
Dan Banach
Thank you, Dan.
I will follow up with the Learning Partner
You've got Fusion.
