Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Motion restriction due to new update
2 REPLIES 2
u1906074
262 Views, 2 Replies
After updating to Fusion 360 2.0.15027 x86_64, I cannot manually click and move the components along the joints. I have tried to ground one of the components and do it, but it doesn't work.
2 REPLIES 2
dan.banach
in reply to: u1906074
Hi @u1906074
All of my assemblies are working as expected. Your Select options may have changed. From the Select menu:
  1. Ensure Component Drag is checked.
  2. From the Selection Priority option, ensure Select Component Priority is selected.
Let us know if this solves your issue.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
u1906074
in reply to: dan.banach
Thank you, Dan. The solution that you provided me successfully worked.
You've got Fusion.
