Model disappeared from screen
emre.ozturkBMMMM
Observer Observer
emre.ozturkBMMMM
Observer
Observer
Hi all
I was editing a model through the history bar, I have switched to another model to create a drawing
I returned back and the the model on the screen disappeared as soon as I panned it.
Then I saved it, closed it and opened again. The model appeared this time but as soon as I panned it disappeared again, each and every time I tried it
If you do not drag (pan) it it keeps on appearing but if you pan it disappears and does not appear again, everything else seems right
Can you please help me in this
kind regards
dan.banach
Hi @emre.ozturkBMMMM
Sorry that you're having this issue. A few suggestions and questions.
  1. Try restarting Fusion, if there is a pending update, this can cause some graphics issues.
  2. Can you confirm that the History Marker is all the way to the right?
  3. Is the top-level assembly active?
  4. Is this issue only happening with one file? If so, can you export it and attach it to your reply?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
kellings
Are you on Windows or a Chromebook? Does this happen for every file, or just one in particular?
Kevin Ellingson
Technical Specialist
emre.ozturkBMMMM
Observer
Observer
Hi
I work on a Macbook pro
This happens on all occasions when I open Drawing module while working on
the Design module on a model or models
As soon as I finish my work with Drawing and switch back to Design and drag
the object on the screen, the object disappears. All other functions work
right except for displaying what is on the screen
My only solution so far is to close the Drawing module and quit Fusion360
and reopen it up again.
Everything turns to normal and stays normal until I open up the Drawing
module
This is time consuming but I am so far alright to get going
Regards
Emre Öztürk
emre.ozturkBMMMM
Observer
Observer
Hi
This happens on all occasions when I open Drawing module while working on the Design module on a model or models
As soon as I finish my work with Drawing and switch back to Design and drag the object on the screen, the object disappears. All other functions work right except for displaying what is on the screen
My only solution so far is to close the Drawing module and quit Fusion360 and reopen it up again.
Everything turns to normal and stays normal until I open up the Drawing module
Regards
Emre Öztürk
o.briggs
Thanks for the info!
In this case it may be a good idea to uninstall and re-install Fusion 360 on your device. Given that it is across all files it is unlikely to be at that level and is more likely to be a bug in the software at the install stage.
If you would like to confirm you can also send the file here or to me personally and I can check it on my MacBook to see if the issue persists across devices 😊
Oliver Briggs
Community Platform & Operations Manager
Please 'Like' posts that are helpful.
If a post answers your question then feel free to click the 'Accept Solution'
