Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
keyboard short cut to scroll to top of browser or bottom of browser
5 REPLIES 5
patrick_william
234 Views, 5 Replies
Because there is no way to organize the browser besides subfolders, I am doing not stop scrolling up and down a long list of components, etc. Is there a keyboard shortcut to go to the very top item of the browser or the very bottom item on the browser?
5 REPLIES 5
Can you use the Home and End keys ? (Or on a Mac  Fn + left and right arrow keys)
Hi @patrick_william
To add onto @edcharlwood suggestion. Creating subassemblies will also allow you to minimize the child components in the browser as shown in the image.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
thank you but that did not do it.
Thanks Dan,
I did the subfolders and that helped yes but I don't think there is a up to the top short cut for the browser. Th HOME and END keys were unreponsive
Hi @patrick_william
I'm not seeing a shortcut key to go to the top or bottom in the Browser. The Arrow keys will take you up or or down one entry at a time in the Browser. If it helps, here is a link to a file that list Fusion's shortcut keys. Click on the link and the PDF will be downloaded.
Does this help?
-Dan
Dan Banach
You've got Fusion.
