Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
joining two very detailed and small parts together
7 REPLIES 7
Message 1 of 8
eoin_byrneWXUV8
304 Views, 7 Replies
so I need to join two parts together but they are very very detailed and small so anytime I try Fusion crashes. I would have designed it as one piece but it is just too complicated as a the two parts had to be designed using python to draw them.
any suggestions would be appreciated
7 REPLIES 7
Message 2 of 8
kellings
in reply to: eoin_byrneWXUV8
Hi @eoin_byrneWXUV8 What method are you using to put the parts together?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 8
eoin_byrneWXUV8
in reply to: kellings
I was using the modify then join where you select a tool body and the other
Message 4 of 8
Can you share the file so I can see if I can help?
Message 5 of 8
there is the two STLS the only way i could join them was export them as stls into blender and join them there which is not ideal
Message 6 of 8
I think I understand - so you want to make the 2 arcs into a semi-circle?
Did you try to assemble them?
  1. Create a new design for the assembly and save it.
  2. Right click on one of the components in the data panel, then click "Insert into current design".
  3. Select a location for the component, then click ok.
  4. After the component is imported, it can be assembled by using the joint command
Message 7 of 8
would this not cause issues when trying to 3d print the part as a whole
Message 8 of 8
You've got Fusion.
