Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Is it possible to make a plane/surface, that has no thickness, but is a solid?
4 REPLIES 4
marks.logins
150 Views, 4 Replies
I'm trying to model mucube:
But how do I make a plane, that has no thickness?
4 REPLIES 4
dan.banach
in reply to: marks.logins
Hi @marks.logins
When you give a profile depth, the body becomes a solid. To keep the model a surface model, I'd suggest using the tools on the Surface tab.
Does this answer your question?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
marks.logins
in reply to: dan.banach
Thank you, "patch" was what I needed. But is it possible to turn a 3D object into just surfaces, so that the inside is hollow?
dan.banach
Hi @marks.logins,
Try these steps to convert a solid body into surface bodies.
  1. From the Surface tab click the Unstitch command.
  2. In the canvas or Browser, select the solid body.
  3. The solid body should be converted into individual faces as shown in the image.
Let me know if this is what you're looking for.
-Dan
Dan Banach
marks.logins
Thank you, just what I needed!
You've got Fusion.
