Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How to seam corner sheet metal Fusion 360
1 REPLY 1
RadoG
246 Views, 1 Reply
How to seam corner sheet metal Fusion 360.
I want to make minimum distance between edge.
1 REPLY 1
dan.banach
in reply to: RadoG
Hi @RadoG
After creating the Flange, edit the Flange feature and try the following steps.
  1. Check the Override Rules  option.
  2. Check the 2 Bend Corner Override option.
  3. Adjust the Relief Shape and Relief Size as needed.
Let me know if this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
