Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How to cut the ID and OD of a part at the same time
2 REPLIES 2
derek_secord12
142 Views, 2 Replies
I was wondering if there is a way to cut the ID and OD at the same time. I would like to see if I could have the tool cut a layer in the ID than cut a layer in the OD and back and forth. The material is so thin it tends to warp from the heat.
2 REPLIES 2
kellings
in reply to: derek_secord12
Hi @derek_secord12 With 2D contour, you will see that when you enable multiple depths there is a Thin Wall option that you can turn on and then specify what you want to count as a thin wall.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Thank you!
You've got Fusion.
