Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How do I delete a team with an education account
2 REPLIES 2
Nwalters2019
101 Views, 2 Replies
 I'm currently using the education edition which only allows for one active team. I need this team deleted or renamed but I am unable to do so. All I can do is mess around with projects. The archive and create features for them. Additionally, I am the only one in the team if it is important. I tried talking to a support but just got trolled and led in a circle. First guy just wanted to stall and have me recreate my ticket for his section( I saved the logs but I don't have them with me), second person probably didn't know how and I missed the third one because I walked away after seeing the big line. Now I am unable to connect live support.
2 REPLIES 2
dan.banach
in reply to: Nwalters2019
Hi @Nwalters2019
Sorry that you ran across this issue. To rename your Fusion Team, please do the following.
  1. Sign into your Fusion Team at https://login.autodesk360.com
  2. On the top-right corner of the screen click on your initials or Profile picture.
  3. Click on the Admin tab.
  4. Confirm that the Team Settings tab is active.
Under your current Team name click Edit.
Does this help?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
kellings
Hi @Nwalters2019 Were you able to get this issue resolved? Can you let us know what the status of this one is?
Kevin
Kevin Ellingson
Technical Specialist
You've got Fusion.
