Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
How do I accurately align a scanned stl mesh to the origin and planes?
2 REPLIES 2
jonpendleton57
217 Views, 2 Replies
7
2 REPLIES 2
Marco.Takx
in reply to: jonpendleton57
Hi @jonpendleton57 ,
Without seeing the specific situation. You can use Move/Copy (shortcut press M) and translate and rotate the model.
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
dan.banach
Hi @jonpendleton57
If you convert the mesh to a solid body, then you could use the Align tool. If converted to the meshes into solid Components, you can use the Joint tool to move them together.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
