Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Getting wrong appearance when applying a material
1 REPLY 1
nguyenkhoi1032003
191 Views, 1 Reply
Hi, I'm new to Fusion360. Could anyone explain why when I apply a material to a body in Fusion 360, the appearance shown on the model does not reflect the actual materal. For example, when I apply Aluminium-Polished to the model below, the appearance doesn't really look like aluminium, although the color of the surface does change a bit. When I switch to the render workspace, however, the surface does have an aluminium look. Is there anyway to make the appearance in the model workspace look similar to the actual material? Any help is appreciated!
Model workspaceModel workspaceRender workspaceRender workspace
1 REPLY 1
Hi @nguyenkhoi1032003 As you have discovered, the materials in the design space don't always reflect the appearance that you would expect them to look like, but they do appear correctly in renders. The colors in the design space don't match well to the real world physical material.
You could create a custom appearance to try to get a color that looks more like aluminum to you, but then it will probably look vastly different in the rendering environment.
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
