Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Fusion Signal Integrity Extension, powered by Ansys MoM Solver
0 REPLIES 0
Message 1 of 1
edwin.robledo
291 Views, 0 Replies
Great News for all Educators and Students
It is known that 90% of PCB prototypes fail when the design has high-speed requirements or needs specific trace impedance for appropriate component functionality. Engineers require tools that will provide them insight and details regarding the signal integrity behavior on their critical traces. Traditionally, diagnosing the root causes of circuit SI failures necessitated using expensive diagnostic equipment. With the Fusion SI extension, you can identify and resolve such issues, offering a more proactive approach to circuit reliability.
I am pleased to inform the educational community that the Autodesk Fusion Signal Integrity (SI) Extension, powered by ANSYS, is now accessible to educators and students at no cost. This initiative is a part of our ongoing commitment to support and enhance the educational journey in engineering and technology.
Overview of the Signal Integrity Extension
With the Ansys-powered SI extension, you can quickly see how adjusting layer properties, adding power planes, or changing trace width can influence signal traces, helping you fine-tune and avoid significant issues on your PCB early in the design stage. By providing access to industry-standard tools, we are bridging the gap between academic learning and practical application, preparing students for the challenges of the modern engineering landscape.
Simple and Easy to use
The best part of the SI extension available in Fusion is that it is remarkably user-friendly. It allows beginners and experienced designers to seamlessly navigate and utilize its advanced features for practical PCB analysis. Take a few minutes to watch our educational videos and begin using the Fusion's SI extension in moments.
Key Benefits of the SI Extension
In-Depth Impedance Insights: The tool provides detailed insights into the impedance characteristics of PCB traces, which are vital for understanding signal behavior and ensuring design integrity and component functionality.
Time Delay Analysis: Educators and students can analyze and understand the time delay effects in their PCB designs, which is crucial for high-speed electronics where timing is paramount.
Resistance Analysis: The extension allows for a thorough examination of circuit trace resistance, helping optimize PCB layouts for better performance and reliability.
SI Resistance: Knowledge of trace Resistance values allows for accurate control of voltage drops and power dissipation, ensuring the integrity and reliability of essential signal paths in high-performance electronic designs.
Inductance: Inductance is crucial for high-frequency circuits, which can significantly impact signal rise times and cause unwanted noise and crosstalk.
Capacitance: Capacitance on traces affects signal speed and integrity, especially in high-speed designs, where it can influence impedance matching, reduce signal distortion, and minimize crosstalk and electromagnetic interference.
Export Capabilities Results: One of the standout features is the ability to export detailed reports and data, facilitating thorough analysis and documentation of signal integrity parameters.
The availability of the Autodesk Fusion Signal Integrity Extension powered by ANSYS at no cost is a significant step towards empowering the next generation of engineers and designers with the tools and knowledge they need to succeed.
Edwin Robledo
Tech Marketing Manager
0 REPLIES 0
You've got Fusion.
