Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Fusion 360 stuck when sending simulation to the cloud - Educational license
6 REPLIES 6
esriel_saf
326 Views, 6 Replies
Hi!
I'm having a problem when Fusuion 360 tries to send my simulation to be solved in the cloud. The program simply freezes during this process, with the mouse cursor loading endlessly and when I try to restart Fusion, my simulation is not even sent to the cloud. I've tried reinstalling Fusion 360 several times, but it keeps happening sooner or later.
I hope someone has a solution to this problem. Thank you!
Labels (3)
6 REPLIES 6
dan.banach
in reply to: esriel_saf
Hi @esriel_saf
Sorry that you're having this issue. I'll ask the Simulation team to look at your account.
I'll keep you posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @esriel_saf
Can you please try to run Fusion 360 Simulation study from a browser (Chrome is preferred)? Go to https://fusion.online.autodesk.com and sign in with your Autodesk Education email and password.
Also, do ALL Simulation studies fail or just one?
-Dan
Dan Banach
dan.banach
Hi @esriel_saf
The Simulation team checked your account and there are no issues or studies stuck in your que. Please try the steps I outlined in my last post and let us know what happens.
-Dan
Dan Banach
esriel_saf
Thanks! I'm goig to try again another simulation and come back here with the feedbacks! The simulation studies do not fail, they simply are not sent to the cloud to be solved. Fusion 360 starts to prepare the simulation, however when it starts to send the studies to the cloud, it stucks at 30% and the mouse cursor loads endlessly and all the program cracks.
dan.banach
Hi @esriel_saf
Can you please try the following.
  1. Open Fusion 360 and the file with the simulation issue.
  2. Make the Simulation workspace current..
  3. In the browser, expand the Load Case and Loads.
  4. Uncheck and then recheck the Toggle Suppress option on a load.
  5. By doing this, there is no net change to the simulation setup, but this will require the simulation to be resolved.
  6. Save the file.
  7. Solve the Simulation.
Please let us know if this helps.
-Dan
Dan Banach
esriel_saf
in reply to: dan.banach
I believe the latest update solved this issue!
You've got Fusion.
