Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
FEA and CFD simultation
18 REPLIES 18
Message 1 of 19
jeremy_camper
731 Views, 18 Replies
what type of files do you import into Autodesk Fusion 360 extensions to do a FEA and CFD... I use a different CAD package
Will it import a .stp, iges, or parasolid to create your mesh and material properties
18 REPLIES 18
Message 2 of 19
dan.banach
in reply to: jeremy_camper
Hi @jeremy_camper
Here is a link to an article that lists the File formats supported in Fusion 360.
Is this what you're looking for?
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Message 3 of 19
jeremy_camper
in reply to: dan.banach
So if I'm reading this correctly I can import my actual NX file into Fusion 360 extensions to do a FEA and CFD analysis?
May I ask, what training is available?
I've done it before but it was in I-deas so it was a long time ago
Message 4 of 19
dan.banach
Hi @jeremy_camper
Correct, below is an image that shows the file formats that Fusion can open. Fusion has built in FEA functionality but does not currently have CFD functionality. Autodesk CFD would be the tool to use for CFD.
It looks like you may  be working company, you may like the tutorials on this page: Self-paced learning for Fusion 360.
Is this what your looking for?
-Dan
Dan Banach
Message 5 of 19
jeremy_camper
So how much would it be to be able to do fusion 360, 360 extensions, and cfd?
Message 6 of 19
dan.banach
Hi @jeremy_camper
You posted these questions to the Educators forum. This forum is aimed at helping educators use Fusion in the classroom.
Here is a link to the Fusion 360 commercial site where Fusion can be purchased. You can chat with an agent by clicking on the icon on the lower-right corner of the screen.
-Dan
Dan Banach
Message 7 of 19
jeremy_camper
I'm so sorry!
I see the simulation but not the CFD
Where am I missing it
Message 8 of 19
dan.banach
Here is a link to the Autodesk CFD site (separate product): Autodesk CFD 2024.
-Dan
Dan Banach
Message 9 of 19
jeremy_camper
Thank you so much for your help
Just being honest, I'm comparing fusion and solidedge simulation
Message 10 of 19
You probably can't answer this and I TOTALLY get it but what makes fusion better?
Main thing that jumps out at me is it imports the actual nx and Catia file
I'm not sure solidworks sim does that
Message 11 of 19
dan.banach
Hi @jeremy_camper
This is a great question to ask on the Fusion 360 Design, Validate & Document forum.
-Dan
Dan Banach
Message 12 of 19
jeremy_camper
For example the Catia and NX files you can import
when imported does in come in with model history or bodies that way you can turn stuff on and off?
Message 13 of 19
dan.banach
Hi @jeremy_camper
When opening designs from other CAD systems into Fusion (and other CAD systems), the feature tree will be lost as will assembly constraints. The parts / bodies should come across. Fusion has Direct Editing tools that allow you to manipulate the imported models, you can turn on the design history and capture new features
Hope this helps.
-Dan
Dan Banach
Message 14 of 19
jeremy_camper
Last question... lol
I hope, can you use simulation (fea) without being on the cloud?
Not sure how customers would feel about that
Message 15 of 19
dan.banach
Hi @jeremy_camper
I believe all simulation studies are now done in the cloud and your data is saved in the cloud as well.
-Dan
Dan Banach
Message 16 of 19
jeremy_camper
Dan
Maybe silly question but wanted to ask
I am going to download the trial of fusion 360 and 360 extension... is anything I test kept confidential/private?
2. Is the trial ever extended? I want to get DECENT that way I can make a educated justification. Lol
Message 17 of 19
dan.banach
Hi @jeremy_camper
The data that you creates is private. You own it and you control other that you may want to invite into your Fusion Team / Project.
You'll have to engage the commercial team about your trial question. I don't want to misspeak.
-Dan
Dan Banach
Message 18 of 19
jeremy_camper
That's what I thought on both cases but wanted to make sure
I don't have anything in mind but was checking off the list
Is there a way I can send you a private message?
Message 19 of 19
dan.banach
Hi @jeremy_camper
You can send a private message by pausing your cursor over my name in a post, and in the menu click Send Private Message.
-Dan
Dan Banach
You've got Fusion.
