Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Educator Help Wanted: Students copying files - File request
0 REPLIES 0
Message 1 of 1
kellings
99 Views, 0 Replies
Have you ever found an instance of your students sharing files with other students and turning that work in? If you have files you could share, it would be helpful to see them. No personal identifying information will be collected. These files will be used to test a potential new tool to help you automate the process of finding files where the students didn't do the work, but turned it in as their own work.
If you have any files that you could share that you know or highly suspect to be copies, please post them here.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
0 REPLIES 0
You've got Fusion.
