Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Drawing doesn't working in Fusion 360
3 REPLIES 3
kimdw356
599 Views, 3 Replies
When I trying to sketch drawing
The drawing screen does not appear,
the FUSION 360 only works by clicking and dragging.
Even other action buttons don't work
enable to click and drag
other button can click  but doesn't working
Please give me answer..
I attached the video because it wasn't enough as a picture
3 REPLIES 3
dan.banach
in reply to: kimdw356
Hi @kimdw356
Sorry that you’re having this issue. In the video I wasn’t able to read the message that appeared on the top of the graphics window. A few questions and steps to try.
  1. Please close and restart Fusion. It’s possible that a fusion update has been installed and restarting Fusion will complete the update.
  2. Can you confirm the version of Fusion that you are running? On the top-right corner of the screen click on the ? > About.
  3. Ensure all the Window updates are installed
  4. Ensure your graphics driver is up to date.
  5. Here are instructions to optimize performance in Fusion 360
    1. Select the Graphics Diagnostics command from the Help drop-down menu.
    Note: Graphics card and setting information are displayed in the subsequent dialog box. If a dual graphics system is being used, make sure that the correct discrete graphics card is in use. See the following link for further information on diagnosing problems on dual graphics card systems: Fusion 360 displays "Your graphics card might not be optimal to run Fusion 360" warning or crashes o....
    1. If the graphics driver date is outdated, update the drivers to the latest version. See How to update graphics driver for Fusion 360 in Windows
    2. Enable (check) the "Limit all effects to provide optimum performance" option. Enabling the option automatically configures the settings and preferences in Fusion 360 for optimal performance at the cost of visual fidelity.
    Please let us know what you find.
    -Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
Hi @kimdw356
Were you able to get the drawings working?
-Dan
Dan Banach
dan.banach
Hi @kimdw356
I'm closing this post as it has been duplicated in the Drawings forum. Please don't post the same question in multiple forums, as this duplicates our efforts.
-Dan
Dan Banach
You've got Fusion.
