Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Do you change your zero position after a facing operation?
5 REPLIES 5
jimmyfos
319 Views, 5 Replies
Do I need to set my zero after every job that has multiple tasks? Does the height of the zero change when the prior operation was a "facing" operation... since the stock of wood will be lower after the cut? or do I need to save the X,Y,Z coordinates and input the same ones manually every time before the next job operation. Thanks in advance.
Tags (3)
5 REPLIES 5
kellings
in reply to: jimmyfos
Can you tell us more about the machine? Does it have a tool changer? Do you need to manually change the tool after each operation? Do you use the same tool holder and just change out the tool between operations?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
jimmyfos
in reply to: kellings
It’s a Shapeoko xxl. Basic function. I need to manually change the tool. Sometimes I need to change the tool between operations with this particular project but others the bit stays on.
Thank you btw!
kellings
I wish I had better knowledge of the Shapeoko. When you touch off your tool, what is the process? Is there a touch pad?
I might consider putting the WCS Z 0 on the bottom of the stock/bed of the machine. That would allow you to use the bed as the tool zero point between each tool change. There are indicators for touching off tools that are of a known height. So that you can zero out your tool and then adjust the Z by the known height of the touch probe used to set the tool.
Kevin Ellingson
kellings
Hi @jimmyfos Did you get anything figured out with this?
Kevin
Kevin Ellingson
jimmyfos
I haven’t tested it yet but I think you nailed it. I’ll give you an update when I do. Thanks so much. I appreciate it and the follow up as well!
You've got Fusion.
