Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
cutting Splines on 4th axis
3 REPLIES 3
ShopXQ3SY
147 Views, 3 Replies
I having issues to make a tool path to cut splines on a axle.  I am trying to use a double end chamfer tool.  I want it to cut from the side of the material instead of it trying to cut from the top.  Any help would be great
3 REPLIES 3
tim_paul
in reply to: ShopXQ3SY
I'll give it a try and report back what I find.
ShopXQ3SY
Thank you
tim_paul
@ShopXQ3SY Here is a quick video. I hope it helps. Please let me know if this is what you were lookin...
https://www.youtube.com/watch?v=rZmP8_Uk13w
A few basic keys to getting it right.
  • Get the correct tool orientation
    • Might need to use a sketch
  • Need to know the z offset distance. This is from the bottom of your tool to the cutting tip on the side.
  • Circular pattern is the easiest way to pattern the toolpath around the part.
You've got Fusion.
