custom python scripts
Message 1 of 29
Hello
with the awesome help of the
Custom Python Scripts for AutoCAD Plant 3D
By David Wolfe
int the AutoCAD DevBlog I started scripting successfull.
On the contrary to the blog, I have to create a part, based on my new script, first before I can test it with 'TESTACPSCRIPT'. Is this actual the typical workaround?
Where can I find a documentation, which sub routines are in which import files (in /varmain), which parameters expect the sub routines and which order is importent for the import files?
Replies (28)
Message 21 of 29
matt.worland
I haven't played with creating supports much, but I don't recall seeing scripts for structural shapes. You might need to create those on your own. And the same goes for the flange dims, you could look in the flangesub and find the flange you are connecting to and see how it is being built. Then create your own getFlangeHubDiameter. But, if you have the known values, it may be easier to create a lookup table.
If my reply was helpful, please give a "Thumbs Up" or "Accept as Solution"
Message 22 of 29
mikael.santospj
Thanks. Do you mean that I can create a method inside my script ?
Clearly, I am struggling a bit with some command lines I see, like: linkFuncToDbman, getParamVal, defaultPipeLength....
I mean, is there any documentation for these advanced topics?
Can I create another varmain, .pyc file (shape)
Message 23 of 29
matt.worland
Yes, whatever shapes you need, you can create your own scripts. You could create a script to house all of the steel data, then in your support call upon that script. Also do the same thing for the flange data. Create a script that has all of the sizes and dimensions you need, then call that from your support script.
By putting the steel and flange data into a different script you can use it in other places and not have to re-write that code over and over.
Just keep all of you scripts together in the CustomScripts folder and they should all be reachable.
Message 24 of 29
avinashkumar797901
Observer
Observer
Its all right. Whenever you have multiple .pyc files, it is stored in that cache folder.
You can check it inside the folder, it goes by name  yourscriptname.pyc
Message 25 of 29
mikael.santospj
try this file: C:\Program Files\Autodesk\AutoCAD 2022\PLNT3D\ContentScripts\variants.zip as already posted here
and the following link: https://tool.lu/pyc/ to see the .pyc filescripts/parameters
Message 26 of 29
mikael.santospj
Hy guys
Another question came this afternoon: Can I use libraries like NUmpy, sympy...?I nee solve one equation in order to get a variable value to draw my geometry.
Message 27 of 29
matt.worland
Yes, as long as they are available on the computers you are running them on.
Message 28 of 29
mikael.santospj
Sorry, but I am not sure how I would do that. Just a simple
from sympy import * ?
thanks for answering
Message 29 of 29
matt.worland
Sympy will need to be installed on each computer. https://www.sympy.org/en/download.html
Once it's installed on the computers that need it, you can then use
from sympy import *
