Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
CB_RTO requester web service unavailable
9 REPLIES 9
Message 1 of 10
SuncoastTechnicalCollege
342 Views, 9 Replies
is there a fix for this ?
CNC Machinist Education Network
https://www.youtube.com/c/CNCMachinistEducationNetwork
9 REPLIES 9
Message 2 of 10
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Req...
Message 3 of 10
@SuncoastTechnicalCollege Did that knowledge network article help at all? Are you having this issue at home or at school?
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
Message 4 of 10
Hi @SuncoastTechnicalCollege
To see if the install is the issue, please try to run Fusion 360 from a browser (Chrome is preferred) by going to https://fusion.online.autodesk.com and sign in with your Autodesk Education ID (same email that you log into Fusion 360 with). If the images are not showing in the Data Panel, then this points to a network issue or it could be the virus software blocking Fusion.
If the virus-scanning software is blocking Fusion 360, you will need to modify the security settings or temporarily disable the virus-scanning software, and then run the installer again. See Configuring anti-virus software for use with Fusion 360
Keep us posted.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
Message 5 of 10
Only at school - never at home
I have the IT department look at that the fix knowledge report
Message 6 of 10
USING WEB Based Fusion - wow I'm on school computer desktop and everything works great _ I see all pics not too slow on mfg regens
I'll see if I can update models to trigger any possible server alerts
I was looking at fixes on knowledge - I see that its mentioned that Fusion uses a Chrome based browser.  I know our district is blocking Google cloud. I have a Google classroom last couple of years. Now I cant access anything in Google cloud as they are BLOCKING Google cloud
Message 7 of 10
I brought my teacher laptop home.  It runs great on home network.  i see nothing wrong
. i consider this a dog but at home its great !!  all the data panels pics.  it runs pretty good.
Message 8 of 10
This is a great indicator that things Fusion needs are being blocked on your school network. I'll post a link to a document of sites and ports that need access for Fusion to run.
Kevin
Kevin Ellingson
Message 9 of 10
Hi Ed. Can you get these links to your IT staff?
Ports and Domains Required to Run Fusion 360
How to Configure Proxy Server and Firewall
Kevin
Kevin Ellingson
Message 10 of 10
will do
You've got Fusion.
