Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Cant assign users to groups
1 REPLY 1
jamie.buysell
112 Views, 1 Reply
Getting an error every time I try to add users to a group. So can't assign fusion to any of my class.
Comes up with an unknown error occurred... Tried removing all users and adding them back in.
Why is this portal made to be so difficult to use. Cant delete teams, can't delete bulk users... Ticket system for help takes forever. Constant issues.
1 REPLY 1
kellings
in reply to: jamie.buysell
Hi @jamie.buysell Sorry this is causing you some grief. We'll get this sorted out.
You can add students to a group when importing. First add a Group under the By Group section and then from the By User section, you can import users and also add them to a Group.
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
You've got Fusion.
