Cannot Split body because there is no intersection. Cannot solid extrude cut because its too minimal and not significant to cut. What am I supposed to do?
brian_merrick
Observer Observer
brian_merrick
Observer
Observer
So I've been having problems with the spit body tool. Like sometimes it works flawlessly and sometimes it gives me a error that logically doesn't make sense because I'm legit seeing the intersection and the red cut line sees the intersection as well. When I do a different approach with solid extrude cut, it gives me another error message saying that the cut would be too small and insignificant enough. I wish so badly that there would be a override button to this because I've pretty much had it with error messages that legit don't need to exist.
kellings
hi @brian_merrick
Can you share or post the file please?
Kevin
Kevin Ellingson
Technical Specialist
If my post resolves your issue, please click the Accept Solution button.
