Fusion Educators (Read-Only)
Are you an educator who uses Fusion (formerly Fusion 360) in their courses in secondary and post-secondary? This is the official Autodesk forum for educators like yourself to share the success you are having with Fusion in the classroom.
Can't stop dragging the view cube.
2 REPLIES 2
bend0006
192 Views, 2 Replies
Working online from a Chromebook. When dragging the view cube, I cannot release it.
Pressing [esc] doesn't help.
Everything just rotates around, when I move the mouse.
Reloading the page also doesn't help.
2 REPLIES 2
dan.banach
in reply to: bend0006
Hi @bend0006,
Is this issue happening on multiple computers or just one? Try clearing the cache by doing the following.
  1. Close Fusion 360.
  2. Tap the three dots in the top-right corner of the screen, hover over “More Tools” and then select “Clear browsing data”
  3. Check the boxes next to Browsing History, Cookies, and Cached Images and Files.
  4. Click Clear Data.
  5. Restart Fusion online https://fusion.online.autodesk.com and sign in to your account
Please let me know if this solves your issue.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
dan.banach
@bend0006
Wanted to check and see if the ideas I gave solved your issue? Also, on Monday night, March 28, Fusion 360 launched a new update. After starting Fusion, let the update install and then restart Fusion. See if this helps as well.
Dan
Dan Banach
You've got Fusion.
